Customer buys a ProTorque starter from a dealer, does not come with bolts. I go to the same store and ask for the starter bolts for ProTorque starter. I get 10-806343  2.
Install the first bolt and the starter is a bit loose.Verify the same with the second bolt. Only recourse was to add a washer from a drive mounting kit to actually have the starter tight.
Loose bolts lead to broken bolts or engine casting failure
