Net Boat Talk
Go Back   Net Boat Talk > Boat Talk > Technical Talk
Technical Talk engine problems, fiberglasss issues, winterizing, or general maintenance questions, post em all here.
Reply
Thread Tools Display Modes
Old 11-09-2015, 07:59 AM
Bt Doctur's Avatar
Bt Doctur Bt Doctur is offline
Bt Doctur is on a distinguished road
Default winterizing tip to prevent cracked blocks
Winterizing tip to prevent cracked blocks
Today, 08:57 AM
This only applies to those equipped with single point drain systems. This is the 3rd boat that I have found the block drains "blocked" with scale.
You MUST remove the quick connect hose and probe the engine block drain holes .
Failure to do this critical stem will most likely result in a cracked block. This also applies to those who have a flushing attachment hooked to the block drains and manifolds. You need to remove the flush hoses to make sure the connections are not blocked by scale.
In fact, it may be to your advantage to completely remove this system and install brass drain plugs.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
