Power dolly design to move a 9000 pound
mcgill
I how a time with my new power dolly design to move a 9000 pound trailer .But it will not move my 18 foot bass boat only 2000 pounds.on my graval driveway.
If instead of concreting my driveway completely, can I sprinkle concrete mix over the top of the gravel and add water to make a rocky surface but solid driveway?
I've never tried that. I would 'think' that would help but not sure.
I've heard of crush n run gravel that will set up like concrete. It has small gravel and dust mixed in the load. You wet it down once it's poured out of the truck and it hardens up pretty good. Call your local gravel place to get the details on how much etc.
Still, can't be sure your power dolly would do the trick on it. Maybe if you could find a similar surface already in existence where you could try it. Your truck won't fit to that spot ehhh or I'm sure you just use your truck.
